No lights on ehc
BIGDOG88
2007 k-9. Bike was and has been running great. Went to start after sitting in garage for 5-6 days started up sounds like running on one cylinder very rich exhaust smell. Long story short checked coil wires to coil plugs plug wires. All good. Started again and only lights under seat is the yellow and blue blinking for cylinder firing. Nothing else headlight blinkers everything works but sounds like hitting on one cylinder. Any ideas please. Thanks
bruce
Ok not sure what you no, but you need fuel, spark and compression to run, most the time it's fuel or spark problem. is it carb. or fuel injected. If it fuel injected you can get software from S&S for free and with a cable and computer will be able to see whats going on. if carb. check compression and make sure you have spark, and then for fuel. once you have pin pointed what you are lacking it will become easier to fiind. If you what to call me maybe I can help more. Bruce 717-382-9983 in PA.
BIGDOG88
It is a carb bike and thats just it will start immediately and run has fuel and spark. Thank you for ur number will give you a call.
X2 on the plugs, and get you some of those fancy gun plug wires the Kaptin selling.
BIGDOG88
Sorry took soo long to tell you the problem is solved. The old saying "keep it simple stupid" applies to me with this problem. It was plugs. THANK YOU for then help.
