No ignition power
awg
What ignition wire are you referring to? Disconnect the negative cable for a bit. See if the system resets. Check the battery, see if it is shorted out.
1 B.M.F.
I have an ignition light on, on my ehc. What does the light mean?
awg
I took a look at my Pitbull. I have no lights on when the key is off. Turn the key on, I still have no lights on although the headlight and taillights are on. When I press the run button then I get a red light on.
1 B.M.F.
I have all lights on except head light high beam comes on when you hit high beam but no low beam mine starts so I looked under seat and saw led for ignition was lit up but I don’t know what that means because it runs I hope yours is a simple fix let me know what you find out out I’m new to this site and still trying to figure how to follow people who sound knowledgeable mine shuts off after about 30 minutes of riding then when it cools it cranks right up .your bike is supposed to have lights when you turn the key on what is the red light that’s on
awg
My Pitbull runs fine. I was just telling you what lights I have on my EHC when starting it up. If I'm not mistaken the red light will come on the ignition module when you press the run button. Kind of showing you there is power to it. No low beam? Check bulb or work g inside the bucket. If I'm not mistaken the high beam comes on automatically when the low beam burns out.
Thanks I’ll double check it I just replaced it a month ago cause it was out
Just saw this, so back to your original issue, may want to check your headlight harness. Open up and Check the connection. They are known to melt and can cause it to short. May be intermittently grounding out.
