Do you mean When the starter is turning it spins then engages randomly ? Or do you mean while riding down the street it will try to engage ?Now the starter is randomly engaging while running, has anyone else had this happen on a 04 pitbull
When im riding down the road it randomly engages starter sometimes it does it 3 or 4 times andDo you mean When the starter is turning it spins then engages randomly ? Or do you mean while riding down the street it will try to engage ?
After you start the bike pull the wire off the starter solenoid and see if the problem goes away. If the problem goes away look for an electrical reason for the starter to be triggered during riding. If the problem stays, pull the starter and inspect it for some sort of mechanical failure causing the jackshaft to keep trying to engage.
Disconnect the wire to the solenoid after you get the bike started and see if the problem goes away. Yes/NoWhen im riding down the road it randomly engages starter sometimes it does it 3 or 4 times and
The problem must be in the starter. The start button provides the signal to the EHC to provide voltage to the starter solenoid which intern activates the starter. It's not the start button sticking because you disconnected the solenoid wire. I would pull the starter and do a little investigating. You can bench test the starter and depending on your skill level repair or replace needed parts. https://www.bigdogpartskingpin.com/ or WSW.The problem stayed after taking the wire off. It's almost like the start button is sticking or not fully disengaging
