slowrower
2007 Mastiff
This ones a bit puzzling, from new I had a slight carb sneeze when holding the throttle steady between 2500 & 300rpms. After installing the V&H BR 2-1 pipes, the Carb sneeze was gone (hurray) and no re-jetting. The V&H 2-1 pipes on deceleration would pop loud enough to think someone was shooting at you - always thought this was because it was too rich!! after making adjustments to the carb (same jets still) it would not go away so I re-jetted from .074 (stock) to .076 and .0290 (stock) to .0320 (secondaries). After re-adjusting the carb (setting it to ground zero) out on the road I go and the first thing I noticed as no decel popping. I had installed new plugs when re-jetting and pulled them after my 10 mile ride and they are a nice tan color so it looks like all is well. That said, bad deceleration popping appears to be also related to running lean - anyone else have this? Another puzzler was when running the mixture screw in yes it will stop the motor however running it almost out would not cause the motor to slow down or start to stall. Time to get back on the road its too nice to be inside!
