Hi all, I originally had a problem with the speedo that had pegged and never reset. I check a lot of the system as recommended and determined that it was the speedo, bought a Dakota and it is great and I really like it. Now here is the problem, after reasembly my neurtral light stays on all of the time. Just so you know what I did, when I pulled the speedo housing apart one of the wires (black) looked like it had come off, actually to a post in the middle. It actually did not even look like it was soldered. So I resodered it to the open one. I was very careful in soldering and taped up all around so I would not get on the other ends. So what happen, should I have not soldered that one, or did for some reason it did bleed over to one of the other connections. I also put the Di-Electro grease over those connections. What did I do wrong? Will it maybe reset? Should I have not put the grease on it? Do I need to make sure the solder did not bleed over? Should I have not soldered that on their? Will it hurt the bike if I ride it. Lots of questions sorry, but thinks.
Dick
Dick
