Neutral Light Not Working -
Within the last two weeks: 1) the neutral light on my bike will not come on when the bikes in neutral. 2) front break actuator will not engage the break lights when the front lever is pulled.
I've chased the neutral wire and can't find a thing wrong with it.
As far as the front break level turning on the break lights????? had it apart all looks fine.
Could both of these issues be the ECU Fucking Up??? If so, Jake PM me please.
RRRUFF
Neutral light, Check your crimps at the switch on the transmission. Had the same problem with mine and had to re-do the connection. Front brake light switch is activated by a small cremaic magnet as you pull the lever the magnet comes into close proximity to the switch and the circuit is activated. You can check this by taking a small magnet and sticking it between the lever and the switch and see if the brake light will come on. The ceramic magnet may be broken off or you may have a loose connection there at the circuit board in the hand control or a broken wire somewhere.
