need some help
crawfish
If anyone can give me some help I would appreciate it. I am trying to change the trans fluid on my '06 K-9, but I can't for the life of me find the drain plug. Can anyone describe how to find it better then the manual does? Or show me a picture? Manual says its near some trap door? Thanks for the help guys.
slowrower
2007 Mastiff
Its very close to where your clutch cable attaches to the scoot ... its small and you may need to move an oil line if its blocked. Be sure you warm you scoot so you get all the old fluid out. I use Redline Shock Proof for Scoots works great!
Mach_1
Carefull when you remove it, the adapter that the plug is in will come out. check out the link on Gas Mans messages it has about everything you will want to do to your Dog from servicing to repairs
