need help
Stimey131
I finally got a reply email back from CCCS "Custom Cycle Control Systems" and Lynn Yaple talked to there tech guy and he said that I would need to replace the studs on the transmission with hex bolts and that 5th bolt on the side may have to be left out. Has anyonyone had to this on their bikes before and is it safe to leave a bolt out like that? Also if replacing studs with hex bolts does this mean I will have thread holes the with a tap that the studs are removed from. I know lots of BDM owners have used this air suspension setup, but have never heard anyone mention any of this before. I have an 2007 Mastiff and I wanting to install the SAS air suspension. I really need some input on this so because I'm having a hard time finding or getting techincal details about the install. Thank you ahead of time with insight on this install. Michael
The link below shows the air suspension I plan to install.
SAS-00 Simplified Air Suspension
kickstart
I have a Bulldog with the factory air ride and a K9 without air ride the little bit of difference in ride is not worth all the BS you are going to go through.
Just my .02
