Need Help...just getting compression release click
Trashman
Been chasing a problem on my 04 chopper. Symptom: Turn key on, hit run button and then start button and all I get is a click. I put my fingers on starter solenoid cover and cannot feel solenoid when I get clicking sound. Placed fingers on front and rear compression releases and I can feel the compression release plungers when starter button is hit. Click is NOT coming from starter. Today, installed new HD battery and same thing. Voltage measurements: (Across battery post with tender plus connected) Key Off: 13.042 Vdc. Key On: 12.580 Vdc. Starter Button Engaged: 12.225 Vdc. Checked green solenoid wire, clean and tight. Removed solenoid cover last week, very minor pitting on all contacts. Cleaned, lubricated and reassembled. I also noticed that, at times, I may not get the red power LED on the EHC when I hit the run button. In the past, I have noticed that if the red power LED does not come on and stay on you can forget about the bike starting. I am in the process of searching resources on the site for troubleshooting this problem. Any direction in chasing this problem is appreciated.
Measuring the Green solenoid wire: Key Off: 0.0Vdc, Key On: 0.0 Vdc, Key On & pressing the start switch: 12.4 Vdc...
