Need a Speedometer Lens
C
cduvall27
Guest
Any of you guys that did a speedometer replacement still have their old one on the shelf that would be wwilling to sell the glass lens? My stock 05 ridgeback speedometer works fine, but has a crack in the glass lens. I can't buy a replacement from BDM without buying a new one unfortunately.
Justintime
Do a search, I think it was Raywood that posted a "how to" on changing the lens. I'm pretty sure mine is plexiglass (also cracked) so you may be able to just cut out and install a new one reusing the reset button.
Dlandbob
Try and make one yourself, I am sure it wouldn't be to hard to get some plexiglass and cut it just right. I think the hard part would be getting the old lens out of the case.
I replaced mine too. hardess part is prying the case to get the lens out. Then it's a little bit of a pain to crimp around the case after you put the new one you made. Good thing is that it can be done. speedo reset button is a poor design. that's why it cracks.
