Motorcycle scissor jack
V
I Purchased this one at Nothern Tool on sale a couple of weeks ago for $69, it is normally $89. Much stronger looking than the picture and works great, those little stands slide right off. I put a piece of rubber shop matt on it. Rated at 1100 lbs.
Torin Jacks Lift Table — 1100-Lb. Capacity, Model# TRE4101 | Motorcycle Stands | Northern Tool + Equipment
Thats a good deal! I have one similar that came with the bike lift. And they do fit under our lower clearance bikes with ease.
BigDogBro1
Made in the USA
Gatlin5
What is the lowest the Torin jack will go measured from the flat top surface?
Just went out to the garage and measured it for you. This is with out the slide on post.
Lowest: 3- 7/8"
Highest: 14- 7/8"
Unit is 6" wide by 18- 1/4" long
And honestly it looks much more stout than the picture in the Online catalog.
Good Hunting.
wyatt580
I use the blackjack. After every ride I pull in on the lift. slide the black jack under and clamp the front tire. Only use kickstand when out. Like V said it goes under easy..
Lowest: 3- 7/8"
Highest: 14- 7/8"
Good Hunting.
Thanks Gatlin for checking the height. The 3-7/8" may be to high. My K9 clearence is just under 4"
