I can't help you with the oil cooler info but If your running hot your engine may be running too lean. Double check your carb adjustments especially if your experiencing excessive Decel pop. Make sure your not blocking air flow over your engine with stuff that's been added to the bike. Use a quality oil.I am looking for some feed back on putting a oil cooler on my BD pro sport ?
Is the oil cooler a bad idea ?I can't help you with the oil cooler info but If your running hot your engine may be running too lean. Double check your carb adjustments especially if your experiencing excessive Decel pop. Make sure your not blocking air flow over your engine with stuff that's been added to the bike. Use a quality oil.
I wouldn't say "bad idea" but maybe unnecessary. After all, most guys don't use them and they didn't come stock or as an option when manufactured. Others may have a different opinion though. I've heard of people adding a fan to help cool when in traffic but I haven't seen it.Is the oil cooler a bad idea ?
Hey, I live by that, oh wait -- you meant the bike!Ck ur jets as Mike said. Better fat than lean...
I wouldn't say they are useless in a traffic jam but they are of limited use.Mike inJersey has a point here. And how do you know the engine is too hot? Cooler isn’t always better. The thing to check besides blue exhaust pipes would be your oil temp. Keep in mind our engine oil not only lubricates, but also provides some engine cooling too. I was pretty interested in what might be the recommended operating oil temps for our air cooled bikes, thinking that oil probably has an optimal operating temp. It was hard to find good data, but I concluded that oil works best between 180-220 degrees. Oil coolers are useless in a traffic jam, and living in the Midwest, I wouldn’t have oil coolers if they weren’t on the bike when purchased. Mine does have oil coolers, which I cover from October through June (or so).
I live in Florida and don’t need them on my choppersIs the oil cooler a bad idea ?
My down tubes are 1 1/4 outside and thank you for the response (offer) I am very interested! I had accumulated a oil cooler from some place or another , but I don't think it's going to work with future plans I have for my bike ! The style you are talking about are more what I was thinking !I live in Florida and don’t need them on my choppers
Nope . If you’re committed to a cooler get what Knothead has. They will look dope on your bike.
