Motor Oil Level???
Chong
U-238
My memory says 1.5 " from top of tank, not fill . Of course the tank sits in there on a angle. So 1.5" from where :) ..
The tank is a resivor, keep in mind the oil tank is part of the circulation so oil always flows in and out of (thru) the tank . If there is oil in the tank then engine is already "full" . Assuming the engine has been run .. When you change oil you drain the tank, not the engine. Unless you scaven the engine.
The none scavenging method i found on here is drain tank, change filter. Add 2 - 2.5 quarts. Start bike get it warm, top off tank to about 1.5" down from top of tank .
Anyhow that's what i do .
J3susisLord
There really is no owners manual specification for that other than 2.75 qts of oil in the bike. Here’s the info right from the’04 manual about your bike in case you need it for anything else. View attachment 135456View attachment 135457View attachment 135458
That is super helpful. That was probably right around the exact amount I put in. Good thing I like math. What you wrote made perfect since. I'm looking forward to getting the remaining 21oz's for next oil change though. Thanks again brother
mleach72
There is no dipstick on my pitbull either. Full is to the bottom of the filler neck. If the oil is down a little bit, it's hard to tell how much oil is in the tank. I made a homemade dipstick out of a straw and electrical tape. From empty, my oil tank holds 3.5 quarts. I put 2.5 quarts in it and cut the straw at the oil level. Then I added one quart and placed tape at the oil level. So the bottom of the straw is "down a quart", and the bottom of the tape is "full".
Mickmorris
Well Known Member
That’s cool! I use a chopstick. Pretty much the same principle. Whatever works!
:chopper: :cheers: :oldthumbsup:
