beast30
I just had my 00' husky in for a dyno tune, to see if i could correct any missing that was accuring. At slow speeds, around 35-45 it misses. Its a slight miss but still a miss.
I did the carb cleaner check on the intake gaskets for leaks and it checked good. The guys at the shop said the timing was right on and the jetting looked good (they only adjusted the accel pump and air mixture a little).
I plan on dropping the bowl tom. and checking the inter jet along with the others for clogging.
Is there a good way to figure out if you have an exhaust leak?
if I remember right, all this sort started when I changed pipes last year And perhaps i didn't get the new pipes seated correctly. Went from sampson rip saws to VH big shots staggered. oh yeah and I'm running a stock super G.
Any help would be great.
