Mean Mothers Baffles?
scubaman15
I looked around a bit but found very little on cutting the baffles in the mean mother pipes ...did I miss it or was it just the homemade washer mod/ and cutting them in half , I want to cut them but it looks like in order for the baffles to fit in the pipes tight "no rattles" they need to stay the stock length Has any one taken any pictures of there mods on this pipe??? :job:
npb4me
I have Mean Mothers, and if you cut the baffle down, you would have to either pop rivet the front or put a screw in it to keep them from rattling. The rear screw only holds the baffle from sliding front to back, it does nothing to help with rattling. I had to do this to my baffles cause they rattled loose in the front.
V
Same here the front rattled bad and I installed a stainless sheet metal screw:up:
BBChopper
Supports 2 Disabled Vets
I thought mine had already been taken out until my rear pipe mount broke. They breathe and sound good in. I’m not messin with it. Looking for a new set though, something different.:hi:
