Doesn't sound like the joint is bad. sounds like the bolt has just seased up in the ball ,might soak it with blaster or equal and try to tap it out, just make sure you don't damage the bolt threads. Oh and I don't think theres ever a bad jointMy rear heim joint spins with the bolt. I can get the bolt of the tranny arm but not out of the joint. Bad joint? Should I replace?
