Lost the top mount bolt What size is it?
SKITZO
Where can I get a new top motor mount bolt, what thread count is it and how long is it.
Thank you guys for all the help, the bike is jerking and squicking all over.
oldmutt
On my 08 mutt the two bolts that go into the heads and the one bolt in between them that goes into the L shaped frame mount bracket are 3/8-16 x 1" long. I replaced the two that go into the heads with 1-1/2" long and replaced the flat washers with lock washers. A lot of blue locktite and 40 lbs. of torque and so far so good.
erldawg
Look in your service manual it should be listed. To be absolutely positive need year, engine, etc: all you have listed is Ridgeback....
erldawg
2005 117ci Ridgeback 300 tire
My K9 calls for 1/2"-20, x 1-1/4", Chrome Hex Ace hardware or Sears Hardware
Mutt same except 1-1/2" length
Mastiff 1-3/4" length.
Ridge not listed my guess is same as K9
That is the Top MM bolt that goes through the backbone frame....Hope this helps
Brew
Earl is correct our ridgebacks take a 1/2-20 x 1 1/4" SHCS, SELF LOCK good luck with your search. I bought the other bolts at my local screw store down town yesterday, but this bolt is a hard to find...
SKITZO
Thank you guys got the bolt from an old school mom and pop hardware store, put in the mount and now the bike sounds and acts the way it should, thank you again for all the help.
