Looking for an open primary cover
ess286
I bought an 03 Chopper that has a Hitech, 4" open primary. The outer cover has a skull and flames design. Well I had to move the controls back to stock length because I am short and the skull now gets in the way of my foot. To switch gears I have to sit pidgeon toed on the bike to get my toe under the shifter. I am looking for a Hitech cover that is normal size and wiont bankrupt me
ess286
For the record I took this pic before I moved the controls back
img7.imageshack.us/i/primaryb.jpg/]
[/URL]
Hitech uses there own bolt pattern so your screwed. You will have to buy from them or have one custom machined using your old one as a template.
Trainguy
Chromeoholic
I would look at fabricating a bracket to mount the controls to (between the frame and the controls). Bring the controls up not out a reasonable amount without causing alot of misalignment on the shift linkage. Would be a lot cheaper than a new or different OBS:2thumbs:
