LIL RAIN AND LIGHTS WENT ON!!!
chihuasbigdog
LATINAMERICAN AFFAIRS
hey, today I went into a lil rain 20-30 mins of wet riding . Oil and Neutral lights went on when bike is running, N led even at gear.
anyone know how to fix this??? BTW I checked 2 hours late with the bike garaged and those lights are still on.
SnakeDoc
Let dry should go out after that. Make sure that you have all of your wires wrapped. That will help, or that is what helped me.
BadBrad
2005 Pitbull
Ditto on the drying out. I've had headlights flashing off and on after a rain and the bike was turned off and parked. Also had tach lights flashing or not reading properly when wet. After it dries, everything works fine again. These Dogs are definitely not Labradors. They hate the water. :job:
phatchopper300
I just wanta ride
Yep same here on the tach. Let it dry out.
chihuasbigdog
Thanks all, next weekend ill be sealing and waterproofing that shitty speedo connectors as I did with those under the tank and the seat!!!!
zipnz
:job:
The ONLY time my neutral light comes on is when the speedo gets wet, no matter what gear I'm in. Otherwise, it doesn't work at all... :job:
RRRUFF
When my neutral light and the oil pressure light came on in a rain storm, water had gotten in the plug at the ehc. Dried it out, put di-electric grease in, good to go.
