lifts
Mastiff Rider64
Would like to know if anyone has used a bike lift from Harbor Freight on a BD Coyote and if it works ok? thanks
Do you mean like the jack lift or the table lift? I have both and use them on my 06 Mastiff and 09 Bulldog Bagger. I had to modify the table lift a little to make it more convenient, but the jack lift the only issue I have is I have to put a 1x6 under the rear tire to have the clearance for the Mastiff but it wont fit under my bulldog (even using the 1x6 trick)
ukkid
[/QU The jack lift...can you roll the bike around on it safely?
Mastiff Rider64
I normally don't try to roll it around cause a zip tie can stop a wheel instantly. I usually park the bike jack it up do my work and then let it back down. But if you keep your floor clean then I don't see why you couldn't move it around, but I personally wouldn't try it cause I'd be to worried of the bike falling over....
I started with the HF red move around lift for the Pitbull. I had to build a small ramp for the front end so the jack would fit (4inch clearence). I could roll it around IF I was Really careful. I had the bike strapped to the lift as well.
