Lifters an 585 cam
ground pounder
I am talking about the needle roller bearing for the cam in the motor case. Always replace it when you put in a new cam! It wouldn't hurt to change the bronze bearing also. Normally if you get it from S&s you don't have to ream it out but always check it with the new cam and make sure you shim the cam for end play!!!
