Chap 5 page 5:
I'd have a pushrod loose enough to show an air gap open enough to move an oring past the rod and lifter.
With aircraft type safety wire, make a long [longer than the tubes x'2] U so you capture oring-21 and run it down the tube(s) from the inside.
Same goes with rings 29, but 31 being the easiest to replace. Repeat by dragging the new rings inside the tubes and out.
Chap 5 page 15.
EOIC valve settings using one cylinder only:
Working at one cylinder only, the trick to remember is to think 'AS SOON AS THE' is the method to EOIC.
With seeing the Exhaust-Open, and that means, 'as soon as you see the exhaust begin to open you stop.'
You now adjust said turns to the intake of that same cylinder.
Turn the wheel and watch for IC or stop as soon as you see the Intake Close. You now set the exhaust rod.
With the book's way of setting watching the other cylinder, you can run this method for a single cylinder so both work the same way.
And if one begins to leak, you are better off changing them all out. Or read the oring as aged-hard/cracked/lost suppleness/cut-pinched from previous work/etc.
We catching the time/money/parts/less parts removed/need replacing?
Signed,
Flat Rate
