License Plate Lights
Byrddogg
I noticed that 2 for the 4 LED lights on my plate were out :bang: Do you have to get new ones from a dealer or can you pick them anywhere? Never took plate apart to see what they look like or anything. Just wondering :confused:
Its a cheap part... order a new LED board from BDM... easy fix!
A pic of Dave's while we were spraying it and waterproofing the unit.
N8KAM
I had 2 out this spring.
You will find that the bulbs are run in 2 circuits with 2 bulbs in each.. chances are that just one is open.. use an ohm meter to find which one is open and if you are good with a pin point soldering iron you can pick up a bulb from Radio Shack #2760320 White 5mm led. swap it out and it will only cost you $6.00 :2thumbs:
Or $20.00 on E-bay for the whole board......
