license plate holder
Noticed the light on my folding licence plate holder, "06' K-9' was flickering. Removed the lens which fell apart and found it takes a four-LED hard wired board. So, I need a light board and lens cover. I do not believe these are proprietary to BDM, any ideas where I can find the stuff?
don't know about the lens but if it is the same as the standard light board, it should be available from BDPP as part #170-00371. found it on there last week. will be the light board w/ pigtail attached to plug into the harness under the right side electrical cover behind the battery.
Called BDPP and you were right, the part number really helped. They had the lens as well. Thanks for your help! Al
