JR03CHOPPER
I developed a leak from my gas tank. The first time...I took it to a shop and had it pressure tested (supposedly). The leak seemed to puddle on the bottom left corner of the tank (obviously the lowest spot). It actually took the paint off, even though it wasn't leaking long. The shop said it was probably the petcock. They removed it, cleaned it up, as well as the bung hole. After they put it back in, it seemed fine. Less than a month later...started leaking again. About 5 drops a minute. Still in the bottom left corner. I drained and removed the tank. No pieces floating in the gas I removed. Fuel line appears to be in good shape. When it was together...I did not see a "river" of gas leaking down the tank. I do not see a crack or hole in the corner (it is down to the bare metal). So if there is a hole/crack...it would have to be very small or in small weld on the bottom, in the well of the tank.
Any suggestions? I was thinking of rigging an air hose to the filling hole and sticking the end of the tank in a bucket of water...and look for bubbles. If I do find a hole...what then? I am thinking bondo won't work, since it is only 4 inches or so above the rear head. Not to mention 93 octane with Ethenol making direct contact.
Help would be greatly appreciated.
