Leaking fork seals
dogvet
Banned
If you're having problems with leaking fork seals, I've found that replacing the stock fork bushings and seals with Harley-Davidson bushings and seals for a 41 mm conventional front end do a much beter job of holding up between service intervals.
This is only for conventional front ends not inverted front ends. If your having fork leaks, when the forks are disassembled, make sure that the bore of the lower fork slider is inspected. when the teflon coating on the lower fork bushing is worn off, it can wear the inside of the slider creating a loose fit between the fork tube and the slider. all of the wear I've seen is on the back side of the bore in the silder down low where the bushing rides.
If you raise your front wheel off the ground, grasp thge top and bottom of the fork slider and try to move it fore and aft. If you get a lot of motion, you should havew the bushings inspected. If the teflon coating is worn off, you need new bushings.
:up:
txchopperguy
Big Dog has a brand new fork seal that just came out...I am getting a set of them this week. I will post and let everyone know how they work.
lee
good info again dogvet - I have the inverted forks - any known issues with them? its an 05 so probably!
dogvet
Banned
I haven't seen many problems with the inverted front ends, I don't think they are quite as prone to leaking as the conventional front ends and they aren't nearly as long as the chopper style bikes.
When BDM used the Ceriani (GCB) inverted front ends, they couldn't even keep the chrome on them and you had to get parts from Italy!
