Kudo`s To Jake On Rubwhores New Gas Cap
RubWhore
Asshole Extraordinaire
I ordered one of Jakes fine spiked gas caps cause I liked Eric`s so much last week and It comed in today and is the shit fast shippin and good gas cap
:up::up::up::up:
RubWhore
Yes dey are badd ass I havent dun the nylon washer thingy yet but it sure is close to the tank gonna due that when I get to work in the mornin as I gots all three of my bikes at my office gettin cleaned by my secratary for da Blowout
jimizee028
TRUE COLORS COLLISION
Do tell more about the nylon washer secret.......i have stock gascap that allows gas to leak up outta the tank through the cap and i am sick and tired of it...so guys please do tell...
Banned
rub is refering to how close the new fuel cap sits next to the paint on the tank.. I found this out when I got mine... looked @ it closely... took the cap apart & installed a nylon washer between the cap top & threaded part. about 1/16th think to raise the cap top just alittle.. jakes caps are awesome, it may be the filler bdm uses to finish the tank.. mine was very close so I did this to help worked great... it still allows it to vent & is not so close to the paint.. rub was having the same issue.. this isnt with a stock cap...
:up::up::up::up:
Rub, I would like to know how much it cost to swap over the exhaust and carb to the left side of the bike and turn the motor around for that matter? :D
:whoop::2thumbs:
RubWhore
Well, Ray I had to do a lot of studyin to acomplish the task..I seen this custom bike one time in a magazine that somebody had left in one of dem portable outhouses at a bike rally I really liked it.....so much in fact that I saved the page and used some honda add from another page to wipe with cause it was really uneke and never really understood how dey did it but the other night I was playin widh photshop tring to make pitchers to have both views...Some how another whiles I wuz doin it the dam pitcher flipped on his own..........beats all I had ever seen it was juz like the one in da magazine at the outhouse carb and pipes on the left like an ole flathead..I kept hittin the undo and it wooden go back to beeins on the right side and I reely wanted my pitcher on my posts
So I just left it alone and figured I would just be the onlyest K9 person around like it width left hand drive and all. :up::up::up:
:loony::roll::loony::loony::roll::roll::loony:
jimizee028
I never even payed attention.....Ray you surely do pay mind to ALL the details.....see what a good long ride does for a guy...
bdmridgeback
Low Down Chop Shop
As for the spacing on the caps, it seems to be that the Landmark Paintsaver ring is supposed to have a thin seal under it, between it and the paint.
BDM, from what I have found, puts them in some bikes and not in others. With the paintsaver ring screwed down tight in a tank without the Landmark gasket in it, the cap will be very, very close to the tank, but should not touch it.
I suggest, if you want more space between the cap and the paint, pick up a bit thicker o-ring to put on the cap. It will need to be the same diameter, just thicker.
That will space the cap out. If you space the cap out in between the splines like you guys are, some day the cap will be tight and the splines may twist and strip out. They need as much surface area as I have given them.
Don't want to see anyone strip out a $200 gas cap! O-Rings are cheap!
Banned
thanks jake I thought of that... but couldnt find a thicker 1.. I did place a thin washer in between the 2 serfaces though.. its a nylon washer,, it still vents fine & works great.. I even thought of putting a roll pin in there for that. my paint saver was one that was leaking & the dealer put alot of green loctite to hold the new paint saver in.. I didnt want to chance removing it to install the gasket..I did install blue loctite on the bolt that holds everything together,, thanks for the advice I'll keep a eye on it..it been holding fine for over 2K miles..:2thumbs:
Mad Dog
ValueTeck Enterprises
Ordered some Dyna Beads and a couple days later they were at my door. Way to go Jake!:2thumbs:
1BADK9
Limited Edition Member
What????? All I understood was wiping your ass with a Honda add, that made sense to me.
Interpreter please, so is the bike really left hand carb and exhaust or is that a photoshop thing? Or are you just fuckin with us Bill?:loony:
RubWhore
:roll::roll::roll::roll::roll::roll::roll:
You will has to cee it to beleves it!!!!!!!
Its a fuckup I couldnt figre out how to fix..then I thought it looked kool cause it wuz diferent it wuz just like the hunda add
