The guys at Triple X carbs are amazing! Fast shipping and quality product and service. I want to thank Gas Man for his "how to install the Triple X " step by step instructions. I'm not the most mechanically inclined person, but his instructions made it easy. I had to remove my l/s tank to remove the coil to access the carb bolts....managed to strip out the center bolt, although I suspect it was already stripped by the difficulty of removal.
The Triple X bolted right on, I replaced the fuel line with a braided one with aircraft type fittings. I followed his instructions to the letter......then came the moment of truth...started right up....made no adjustments.....and went for a ride.
Okay, I purchased my 05 Pitbull off the showroom floor...it had the Super E carb and stock pipes at the time. I added Ness pipes and the D&M spike. Ran ok, but it was lacking. Went to the G carb and a set of Yaffe pipes....disastrous ride.....backfired, no mid range, continuously adjusting carb. I then went to the V&H big radius pipes...better, but still lacked that umph....got rid of the spike...figured 6 years was 6 years too long and replaced it with the stock as a temp....ran better...but still lacking....rebuilt the carb....no change....saved up my pennies and took the Triple X plunge along with a Ness 90degree air intake....just got back from a short ride and smiling ear to ear.......what a difference...immediate throttle response, power all the way through the gears....no backfire, no stutter - things I was dealing with for 6 years.....Gone!!!!
If you are experiencing these same things....go with the Triple X - I didn't even have to adjust the carb.....I may pick up the idle, but good right out of the box!
