Jetting
My Bike: 04 Ridge Back
My Biker Photos
Rep Power: 0 Jetting
Hi Guys
I have a 04 Ridgeback with a 107,V&H BR,Forcewinder air cleaner, Elevation is 1700ft. What jets should be in the carb.? After doing the recommended carb adjustments, I still have a flat spot on acc., I believe the jets are stock 295/70. From what I'm reading in some of the threads here I think 31 int. but not sure on the main.Any help is appreciated.
RBR
V
You might open up your idle mixture a bit to see if that helps. But if its flat from idle to 2500 that sound like more than just a "spot". Have you checked the accel pump? Also how do your plugs look?:cheers:
bruce
intermediate jet is normal riding, main jet kicks in on hard accel. You can get adjustment info from S&S on line, even print it out. I am running .33/and .74 and I get about 45 mpg.
T.Byrd
With the breather that you are running try taking the vent screw on the left side of your carb.out.Just try and see. Recommended by s&s on this style breather.
