That is correct, with the automatic valve! With the Manuel you direct where the oil flow goes. It's just that a automatic bypass & a Manuel bypass. I guess I figured people understood that. The automatic : the valve bypasses the cooler till the oil is to hot then a double plunger one opening to the cooler and one closing the bypass allowing oil to go through the cooler where it is air cooled 10*~20* and returned to the oil tank. With the Manuel bypass. You divert the oil yourself from and not allowing the oil to go through the cooler but streight back to the tank.
