Is this a developing problem???
Old Hippy
It's 4:20 somewhere
My Scooter's got a new quirk.!!! Once I turn the ignition key on, all the required lights activate, including the high beam indicator light(faintly, but it is lit). Once I start this monster, and rev it a few times, the high beam indicator light fades even more, but as it returns to idle, it FAINTLY glows from time to time. Is this an indication my EHC is starting to puke???? I am on my second one now. I sure hope #3 is not in my future..!!!
Damn these EHC's...
V
i must live too close to the ghetto.
ever here of formaldehyde?
dip some weed into that and smoke it and you'd wish you were dead! :down:
Not to change the thread but back in the day the local funneral home got broken into and yes the stuff around here was enhanced with enboming fluid:bang:
Cutter
Sounds like moisture in the speedo housing to me...
Mine often does that after I get caught in the rain, or xtremely high humidity followed by heat...
Old Hippy
It's 4:20 somewhere
Thanks Cutter
FINALLY, a sane answer.!!! That could just be the prob. I'll do some drying and see if that helps.!! It has gotten to the point ALL my indicator lights are starting to act up.
:2thumbs:
Agentbman
Mine does the same with the Neutral after i got caught in the rain. I took the speedo off and took compressed air to the connections....a little di grease and good as new.
:flag:
BigDogBro1
Made in the USA
Is there any room available inside those speedometers to place a small desicant pouch to help keep the moisture down inside?
