Inverted forks
blazen582
I have read a few post about doing an inverted front end. I am getting ready to order the American sus.. P7. And I would like to clear up a few things that I see bits and pieces about.. I have a 06 k9. My question is after I order the front end what else do I need to buy? Will all my fender brackets still work? Will my rotor work on the P7? What about wheel spacers? Also can I use my same handle bars? When I order the front end is there different lengths? Thanks so much for you guys help. Last if someone knows who is the best to buy from let me know.
Ps. Once I figure out what I need to keep and not keep off the stock front end it will be for sale.
MARV
bars should be OK as its 3.5" o.c bolt spacing.
most likely will need axle spacers for the wheel and spacers for the fender brackets. will have to measure when installing.
need to check what year brake mounts come with that front end. BD is 2000 and up.
rotor will be fine. you'll just have to space the caliper to it.
yea there are different lengths but just tell them what you have. 06 ridge is 3 and 12 over?
