Pretty kool wheel/brake setup.
Motorcycle Fabrication | Glenndyne Design
This is a true blend of form and function. The brakes and the rotor assembly are housed inside of the 2 wheel faces. The caliper bracket is indexed to the axel assembly, which is secured and slotted into the frame adjuster block or lower leg of the front end. These things look like exotic, high performance car wheels form both sides! The wheels are just another fine example of what Glenndyne is capable of.
