Intermittent loss of spark, 2004 Chopper
Moespeeds
2004 Chopper, owner broke down today and called me. An experienced mechanic checked for spark on site and had none. All other functions, headlights, starter, etc were normal. When I got there an hour later, bike started and ran normally. I checked the crank sensor and tried heating it and can't repeat the problem, bike starts and runs fine. EHC has the new daughterboard. I'm thinking bad crank sensor or coil, but not sure what to do since I can't repeat the problem. Any suggestions?
mobsta
could very well be the cam sensor,04 dosent have crank sensor but same issues,seems theres been a few bad sensors lately,there is some test you can do with a meter
Moespeeds
Cam sensor, sorry Mob. Got 12.2k across the coil, is there another coil test I can do? Short of taking this thing out and flogging it until it dies, what else can I check?
mobsta
have you tried the search,there was 2 brothers on here just recently and posted the test,dennis worked with them,one of them was puredestruction.you can actually test the cam sensor.have you looked at the cam senor?some times you can see the problem,like burned or something,sorry i cant be of more help but search cam sensor youll find the thread with the testing,good luck:cheers:
mobsta
you could try looking up post by drbarnhart,that is dennis,he helped these guys check the cam sensors and coils
RADAMS445
RADICAL
Moe...Hate to say it ,but recurrence is the first step in solving the failure.:up:
Moespeeds
Control board and key switch are ok, bike turns over, all functions were working except spark. I rode the bike yesterday and couldn't get it to die. Owner has opted to change cam sensor and coil for peace of mind. Anyone know the part number for a stock coil? They are Crane coils, right?
Yes, they are Crane 3 ohm single fire coils. But I haven't heard of them going bad on here. Might check the plug wires too.
Opps, just checked your first post. Think the 04s were still dual fire not single!
Moespeeds
Thanks, I got it Ray, somehow I knew 2 wires was dual fire, I just forgot to get the part number last night when I checked the coil. Plug wires looked ok.
