intake manifold help please
jm96732
can any one tell me if the 117 intake is a stock evo or twin cam or if it is .050 shorter evo like on the 107? i want to put my patrick racing dual carbs on my bike but not sure if it will fit because it is for a s&s evo style 107 or 113 with 4 inch bore and it is 0.050 shorter then stock. any info will be greatly appreciated.
thanks john m
LamboV12
Hey John
I had the exact same issue when I went to Mikuni set up because I had previously swapped out the intake. It takes the wider intake, the same as a Screaming Eagle HD evo motor.
X-ray Doc
John,
It is the height of the cyl. that determins how wide the manifold needs to be, longer stroke needs wider manifold. The 107, 113, 117 all use a different manifold. The 117
uses a S&S # 408 I believe.
