do you have number?
Yes, i'm taking my rear pulley off this winter and sending it to themis supermax still is business since the old man died. haven't heard, or don't recall.
https://www.google.com/url?sa=t&rct...n.com/&usg=AFQjCNGFsXYfHV6rFD8Zs7A4YMW64ZjF4wI need a 34 tooth pulley for '07 Mastiff. Baker #34t-dd6r.
Thanks
I believe he's needs the front pulley not the rear, but that's good info for the rear pulleyDo you still have your pulley, but the teeth are worn out??? If that's the case, send your pulley to http://supermax.net/ and have some poly teeth put on your existing pulley. It's well worth it!! I ate through 2 rear pulleys before I had mine supermaxed... never had another issue!
Don't forget the nut is left handThanks for all the help. I have one on the way.![]()
