Identify these bars for me
I am trying to track down a button cover for the right turn signal on these bars. Bike is new to me and missing one cover. It is plastic on the left side but rubber would be fine also. Thought about trying a Harley odometer reset button. Can someone also fill me in on the sequencing for flashers and turn signal ? Seems like a very light press I get turn signal but if I push too far I get flashers.
Those are not stock.
I figured that bc I have the receipt from when he paid for them and they weren’t cheap. Trying to figure out if they were complete custom or were an aftermarket produced where I could obtain a new button cover. Receipt only shows handlebars and were put on at a chopper shop in Birmingham AL that I believe is closed now. Love the bars and how they feel
They look like stock bars, with after market controls.
I noticed that today there is a big dog emblem on front. Also realized today I have no horn. When he deleted the controls, he apparently deleted the horn button. Gotta find me a “good” inspector now
pknowles
RETIRED
Horn is probably still behind the electrical cover. Just power it up and add a push button in the cover. Just a thought.
Which cover are you talking about ? Where ignition key is or handlebar controls ? I believe manual says grey wire. Can anyone confirm that ?
Stock bars they cut down and mounted what looks like PM switch housing single button. Do those run the turn signals? Not sure what happened to the front turn signals. How do you start it, slam button?
Previous owner looks like they changed the wheels, not sure what those are.
here is the replacement button. Looks like you have to re-wire it all unless it will pop off.
Dang that looks like them but I just want the cover. I’m not messing with rewiring. Yes they work just blinkers. He put a button down by the key that works the ignition. Also the high beam/low beam switch but not the horn for some reason
Well for $9 its worth it to see if you can pull that button cover off. Well will probably be like $15 with shipping, but still worth it it will either come off or you have your replacement anyways.
I think the switch is just the yellow button which is what I have now. I think the housing part which is $179 is what included the black button cover. I’m going to call performance machine tomorrow and hopefully get that part number. Figuring out the PM manufacturer was the key so thank you for that
