PROFLYER
SWOLE
Ok, I just had an idea while looking at the open belt drives...from what I understand (and please correct me if I'm wrong) our tranny's are put under lots of load and torque laterally (perpendicular) to the tranny shaft which is causing failures. Also, I've noticed that the clutch hub/carrier wear is almost ALWAYS on the left (when looking at it) side of the inner primary...could this also have something to do with the flex of the tranny shaft and probable failure of the related bearings????
Most guys run an outter bearing support bracket when doing an open belt drive...how hard would it be to make the primary cover stiffer and have it provide the same type of outter support in the wet (stock) bikes? I'm not an engineer by any means but this seems like it would be somewhat simple to design....
Discuss
Discuss
