RRRUFF
:bang:
Alright, I have got a problem that I need some help with. I have been experiencing this for a few months now and it is an intermittent problem. Start the bike before leaving to go to work let bike warm up. Start out no problem and then somewhere in the 25 mile ride to work while running 60/65 mph, bike will just shut off. It’s just like you hit the stop button. Checked start/stop circuit board out and found what I thought was the problem but NO
. Bike shuts off again this morning. I can twist the throttle a couple of times and the engine will fire/ back fire (exhaust) but not start. It will do this a couple of twist, then nothing. Head light & running lights still working. I then can switch the bike off and then back on, hit the run button and it will fire back up and run with now problems. It may do this a couple of times in the 25 mile run to work. Then, so far no problems on the ride home. I am thinking electrical and I have check wiring under the tank, head light, tach board and the controller on the right handle bar. Switching the bike off and then back on makes me think electrical but twisting the throttle and getting it to fire/back fire makes me think fuel.
Any one else have this problem with these symptoms?
Oh it happens at other times also, not just while I am riding to work but usually when the bike has been sitting for a while, day or two. Also this morning it did it while going the gears.
. Bike shuts off again this morning. I can twist the throttle a couple of times and the engine will fire/ back fire (exhaust) but not start. It will do this a couple of twist, then nothing. Head light & running lights still working. I then can switch the bike off and then back on, hit the run button and it will fire back up and run with now problems. It may do this a couple of times in the 25 mile run to work. Then, so far no problems on the ride home. I am thinking electrical and I have check wiring under the tank, head light, tach board and the controller on the right handle bar. Switching the bike off and then back on makes me think electrical but twisting the throttle and getting it to fire/back fire makes me think fuel.Oh it happens at other times also, not just while I am riding to work but usually when the bike has been sitting for a while, day or two. Also this morning it did it while going the gears.
