Sorry I didn't see this thread before but if you would have searched you would have found that out as it's been discussed here several times before. No room in the DSSC cases!Well I can tell you for sure the M-6 will not fit a chopper with DSSC not enough room for it to fit behind the case
I did get the Harley primary automatic chain tensioner to work I had to grind the webbing under the adjustment plate but it fit and works great.Sorry I didn't see this thread before but if you would have searched you would have found that out as it's been discussed here several times before. No room in the DSSC cases!
