How to remove burnt oil from polished jugs...
Rally
Well my 05 Chopper has developed a small oil leak (rocker box) on front and back polished jug.
Being how the motor is "hot" the oil has baked on. :angry:
The leak looks worse than it actually is especially when I run the Dog hard.
Any sure ways of removing the oil baked on the polished fins?
Which gasket set is best for the 117" motor w/TP rocker boxes?
Thanks
BADOG
Rocker Box Gasket
I just had to change the gasket.
I spoke with S&S directly and they were very helpful.
Here is the information they E-mailed me.
Spencer Michael mspencer@sscycle.com to me
The Drag part#, DS part number 90-4111.
Page 473 of Drags fatbook
Mike Spencer, S&S® Cycle, Inc, Customer Support Center, 14025 Cty Hwy G, Viola WI. 54664, Direct Line 608-627-0256, Fax 608-627-1488, Email mspencer@sscycle.com, Website www.sscycle.comthe upper corner, or call Mike
:up::up:
Rally
I tried brake cleaner on a rag and not much luck.
Then brake cleaner on a scotch brite pad and the baked on oil came off with a little elbo grease.
Oven cleaner if it were to get on the paint could do some damage.
