How often Do I need to change my oil?
I have a 2005 Big dog Ridgeback. I changed the oil and filter a year ago. 370 miles on the oil change. The motor has 8800 miles on it. The oil is a little dark. Should I change the oil once a year or should I wait until the end of summer. I might put 600 miles on it this summer. Thanks.
Brandon Downey
Manufacturer recommends every 2500 miles. If you happen to have your owners manual there is a service schedule in there.
Brandon Downey
Ok cool. Maybe one of the guys on here with same year bike and owners manual can confirm that for you. Mine is a 2007 Mastiff. But with your situation I think I would change it at the beginning of each riding season since you don't put that many miles on it.
Reddickracing
Yes sir agree with the above guys. Change at the start of season, spend extra and get synthetic, change at least once a year. To cheap and easy to do. Oil is the life blood of the motor.
Brandon Downey
Absolutely on the synthetic. S&S recommends synthetic as well. Not even sure why anyone would run the conventional oil in the Dogs, the full synthetic is only a few dollars more expensive.
Big D Florida
Time, as well as mileage, is a consideration. Under heat and pressure, even synthetics produce corrosive compounds that remain suspended in the oil your bearings are soaking in.
I agree with the above, especially Unsprung, and Reddickracing... they make very valid points.
