I apologize if this posting in the wrong location & or the question has been asked before.
I have a 1999 BDM Bulldog with a 5 speed baker, and at low speeds the bike seems to rock back and forth, I checked the primary and it appears to be per manual specifications. I don't hear any slapping noise and clunking either, While the bike was on the stand I placed it into gear and rotated the tire and found that there seemed to be a lot of rotate, of course I didn't record the distance of rotate, but willing to check again providing someone can give me guidance as to where I should take the measurement.
note: the bike shifts well and have had no problems to date, i just hate this low speed creep so much that i usually pull the clutch in so not to be so embarrassing, it is as if i need a lower gear (example: its like an old ford pickup that has a bad ring & pinion gear, but that's usually worn teeth or a broke tooth). I did contact Baker about a 6-speed but clearly don't want to invest in something that will not fix the problem.
Baker asked me this question:
How much can you turn the wheel before you get positive contact
Thank you in advance.
