"Hole lotta Shakin goin on"
Big Daddy 72
Custom Street Rod Interiors & Design
Got a couple questions, prob not in the right spot here sorry bout that...
Rode my bike couple days ago and noticed the back bolt that holds down the coil cover was gone, and the front one was loose. Where can a person buy chrome Allen head replacement bolts?
Gas tank seems to be Shakin a lot. Is that normal? 06 mastiff. Doesn't seem to be super loose, but if you push down just slightly on the end closest to the seat you can feel and hear metal to metal hitting.
mjsk9
My local Ace Hardware has chrome allen head bolts. For the gas tank, make sure the mounts are tight. The mounts on my K9 have a rubber inserts to absorb vibration, perhaps those are worn out / become hard?
Nukeranger
Nukeranger
Doesn't sound right from your description but they do have vibrations compared to Jap or modern day British bikes. Find out what's loose and fix it.
There is also a plastic washer that goes between the bracket and head.
Don't forget this either. Its kind of a fiber style washer. It acts as a heat barrier. Keeps the coil cover from getting way too hot, sorta.....
Big Daddy 72
Does it go underneath the coil cover or just under the bolt head?
Brew
ACE hardware, Lowes and Home Depot in the chrome bolt section. Anyone of them will have them and yes get the nylon washers, you need one under the front and one under the back mounts...
