Nukeranger
Nukeranger
I haven’t tried Deka ETX20L yet but I’ve had good luck with my Braille lasting about 5 to 7 years each before the cranking amps become an issue. The removed Braille goes into the Riding Lawnmower but right now my Lawnmower has had a Walmart Battery for about 3 years so I leave it alone. All my spare used batteries sit on the garage concrete.
Every battery I own gets its own trickle charger or I rotate a charger around. Even the used spares. All these damn new cars have so many electronics on them it’s crazy. So, the only real battery killer around here is the Corvette so I keep a charger/maintainer on it. I changed it out this year but probably didn’t need to. At least I have a ready to go boat battery.
I thought you had to use a special lithium battery charger unless things have changed. I have a Lithium motorcycle battery sitting on my bench with its own charger and had used it a long time ago when the Daytona 675 battery needed replacing. That sucker is so small and light but I would not keep one on a motorcycle.
Long story but I would stick with Deka or Braille and always have some good trickle/maintainer chargers around.
