GDOG_PITBULL
Looks like I need a new bulb as I have the blue light on and no output out of the light. Can not toggle between high and low either. Any comments?
G
G
Steve's correct, this is very possible! :2thumbs:Possible EHC issue. Do you still have the ugly black block?
yes, I have been very lucky with this so far.Possible EHC issue. Do you still have the ugly black block?
GDOG_PITBULL,
But...do check the inside of your headlight bucket. The Headlamp Plug may have also melted down! It's a very common problem on the '04s through '06s! Service Bulletin SB-1077.
If it did, contact Steve, he has the "permanent" fix for that! :2thumbs:
dead![]()
What's the permanent fix? I've had a loose connection in my headlight housing also.If it did, contact Steve, he has the "permanent" fix for that! :2thumbs:
dead![]()
What's the headlight plug inside the bucket look like?Ok, pulled the bulb, the high beam indicator goes out. Checked bulb with voltage across both filaments or high and low and both burn bright. Battery ready 20 VDC across the posts..???? I may never understand this.
So, from the last ride 6 weeks ago till now the headlight no longer works and it has just been sitting in the garage on a tender. Whats next? VR, CB, EHC...?????
G
BDM kit# 173-000012-00What's the permanent fix? I've had a loose connection in my headlight housing also.
Looks just fine, not melted at allWhat's the headlight plug inside the bucket look like?
Pathway is from the headlight plug back to the EHC then to the battery. No VR, or breaker involved, neither are the hand control switches. All power derived from the EHC then to the battery.So the voltage is derived / circuit path is from the socket back to either the Hi/Lo switch or the CB, then VR???? Losing my cookies somewhere along the path. May need to sniff around under the tank???
G
No I sure don't. Bike ran last week but that does not mean the EHC is not going south!Pathway is from the headlight plug back to the EHC then to the battery. No VR, or breaker involved, neither are the hand control switches. All power derived from the EHC then to the battery.
Do you have the schematic on the '04?
:2thumbs::2thumbs::2thumbs:Well a problem that I encountered some time ago reappeared and caused my headlight / highbeam indicator problem.
The damn main EHC connector that I was sure I had checked was once again the culprit. With the key on I wiggled it a bit and all of a sudden I had lights, camera and action.
Now I just need to figure out what the deal with the starter spinning and not flipping the bendix in to engage is.
Thanks all!!!
G
