Help??
Jaxowl62
Rather confusing site..... need tech advice.... 2006 pitbull....battery volts check good!!.. CCA on load test checks great!!... yet.. intermittent start problems.. hit start button.. starter turns maybe 1/8 turn ( estimate ).. then stops....?.. let bike sit on charger for hours.. later... hit it every time. it fires!!.... rode bike.got hot.. checked again.. bits every time.. let bike sit 24hrs.. same problem!..... put back on charger.... hits off!!..
Could this be possible starter issue??
JAXOWL62.
Thanks for any advice!
Have you checked the starter solenoid?
Noting confusing here.. way better than the other site.
hoat
check the battery terminals for tightness and maybe you need a new battery if its not holding a charge
Chopper Dave
SIICK!!!
check battery terminals...make sure they are tight....and if you have a bad cell in your battery....it will still have a green light on the tender....but the battery won't keep a charge....
confusing:confused: pretty self explanatory site......go to forums...then scroll down to which thread you would like to read...example.....Technical, customizing,performance,etc...how can that be confusing??:hi:
Yeah, as Fat Cat on the other site explained...
The bike needs to hold a 12.8 volt charge. Say after it sitting for a day or so.
hoat
that guy never checked back in thats what I am confused about:angry: :loony:
rowdy13
good impersonation Chopper Dave. What was confusing, was trying to read his post.
kickstart
He comes into our house and doesn't say Hello or do any kind of intro, just makes a negative comment about our home and wants us to fix his bike. :nono:
