Help with exhaust flange kit
Davepick
Just received my new pipes, they are Martin Bros Daisycutters and they look awesome. Now I need an exhaust flange kit and I’m not sure which one I need, drag Specialties has one but it only lists a bunch of Harleys in the fitment guide. I am pretty sure some of you guys have fitted Martin Bros pipes before so can you remember which flange kit I need?
V
You might look at the flanges on your stock pipes they may transfer on to your new ones. Worth the look any way:up:
Also a Harley flange should work as well
V
hoat
usually the flange kit from your old pipes can be used on your new as said above . just pop off the ring with a screwdriver remove the flange put on new pipe and replace the ring, repeat, done!
Davepick
Thanks guys, from the Martin Bros web site it looked like i needed new ones but looks like i can use the ones off my existing pipes.
Of my 5 sets of pipes I've used the stock flange. No issues.
