HELP No power
Fitzy
I have had my bike parked up for about 4 weeks on a battery tender went to start it today no power no lights no nothing battery is reading 13.2 v any ideas
before I start pulling it apart Thanks in advance.2008 Mutt :confused:
DRBarnhart
Insert title here...
Possibly an ignition switch problem? Disconnect it at the first plug and jumper it (bike side going to EHC). Anything?
Dennis
How about that relay under the seat or main switch you reset with a push button? Main fuse is first.
RRRUFF
All good suggestions, I would also check the ignition switch and connections. Don't forget the ground cable from the battery to the starter mount. Crimp connections also.
Fitzy
Thanks for all your input guys tried it again this morning before I started pulling it apart and it started like normal so I don't know what was wrong bit of a worry
Mine as done that a few times and have to agree with Dennis on the ignition switch. I just turn it on and off till it works. Just got a new one but haven't installed it yet.
makithapn
I agree with Sven :confused: probably the relay next to your battery, only thing that will reset itself when it cools of or dries out
