help it wasn't the idle screw
jeepenbob
I was trying to adjust my idle turned the screw up front by the throtle shaft like a dummy Ididn't count the turns now i have a decel pop how do i adjust this back I have a short e s&s I also found out the idle screw is on te back side of the shaft :confused: :confused:
surferdude
dry docked
Decel pop could be running a little too lean ... turn the air/fuel screw out counterclockwise 1/4 turn .... check your plugs to see if it's burning clean.:2thumbs:
